'Slot depth less than or equal to ball radius' - best way to make a shallow slot...
Hi Guys,
I would like to make a 'ball-end' slot type feature using the 'slot' command. The slot depth I require is much less than the 'ball-end' diameter. I would call this a 'shallow slot', i.e. I just want to touch my 'placement face' with the end of my ball-end slot. What would be the easiest way to do this? I could do this with a swept feature but was wondering if there is another way...
many thanks,
James
using NX6
RE: 'Slot depth less than or equal to ball radius' - best way to make a shallow slot...
Is the face planar?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Just in case it IS 'planar', see the attached example as a possible solution.
To vary the 'depth' of your 'shallow slot' simply edit the offset distance parameter of the Datum Plane.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hi John,
perfect explanation!
many thanks,
James
