Manufacturing module, mill contour
Hi everyone!
I'm new using the manufacturing module in NX. I create programs for molds machining.
I use 4 operations:
Operation Stock Tool
1. CAVITY MILL (follow periphery) 0.500mm 3/8" end mill
2. CONTOUR AREA (zig zag) 0.250mm 3/8" ball mill
3. CONTOUR AREA (zig zag) 0.125mm 1/4" ball mill
4. CONTOUR AREA (zig zag) 0.000mm 3/16" ball mill
The problem is that when a CONTOUR AREA operation is done, sometimes it leaves a lot of stock in small areas for the next operation, and resulting in tool breaks.
So, I want to know if there is a way to machine this small areas with multi-depth cut. I tried with cavity mill but it wastes a lot of time, I also tried with the option of multi-depth in 'cutting parameters', but not success.
I attached an image of what I am talking about
NX6.0.3.6 -> NX7.5.4.4 -> NX8.0.0.25
RE: Manufacturing module, mill contour
It sounds like you should use REST milling and/or Flowcut with a reference tool. We've starting using REST with good results. Hard to understand at first, but gets better. Start with the wizard. Flowcut looks interesting, but we've not used it much yet.
Good Luck
Try using z-level profile and use a reference tool to clear out any corners before using a contour operation. I could not open your image for some reason.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
I couldn't open the attachment either. I guess what you use depends on whether it's 2D or 3D. Flowcut for 3D or z-level (or REST) for 2D. I forgot about the Reference tool option with z-profile.
Thanks for your comments.
I used REST MILLING and it seems to work. I'll tell you if something goes wrong.
