Punching shear on a pipe cap
Any tips on how to calculate the puncing shear on and end pipe cap will be appreciated.
I have a 16" pipe welded to the end cap of a 24" pipe resisting a 15 kip force. Using STAAD FEA I get plate stresses that do not make sense and I like to check them manually.
RE: Punching shear on a pipe cap
There are such things as reducers.
What would you be doing, if you knew that you could not fail?
