Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The forum looks great! You guys have done a fantastic job on arranging things there...Your site is very precise and fun to visit..."
Geography
europipe (Chemical)
23 May 12 9:29
Company wants to have a new undergr. firewatersystem.
Competitors accusing each other about the used resin.
How can we test the used resin of a pipe.
We want it to be epoxy.
Send it to a lab? If yes; whitch lab in W-Europe?
Some help greatly obliged.
Pud (Mechanical)
23 May 12 10:03
These are (used to be?) the top UK plastics research lab.
http://www.rapralimited.org/
I would guess most European countries will have their equivalent.
www.tynevalleyplastics.co.uk
Beauty is in the eye of the beer holder.
Helpful Member!  patprimmer (Publican)
23 May 12 18:46
Sometimes major resin suppliers have a commercial analytical department. I know DuPont does in Sydney Aus.
Any colledge/uni/polytech type institution that offers polymer science degree courses should have the capability and probably the interest.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
europipe (Chemical)
24 May 12 1:32
Maybe should be more clear about my location.
Should be a lab in Belgium/Netherlands.
Pat, its not the issue about the resin supplier, its more the issue about contractor has used the right resin; but its a very good idea to contact that suppliers.
Thank you very much for your input.
24 May 12 3:07
Resin suppliers know more about what resin is what and the different grades both they and their opposition offer than just about anyone else does.
Pat
for site rules
europipe (Chemical)
24 May 12 6:13
Yaeh, you are right.
We just want to know the contractor has used epoxy and not cheaper, p.e. ortoph. resin.
Certificates are in my opinion useless, the most misused and copied pieces of paper.
Greetings
24 May 12 6:29
So what is the property that warrants the use of the epoxy.
Pat
for site rules
europipe (Chemical)
24 May 12 7:14
HDPE pipe what is now underground, degrades very fast, we understand epoxypipe is the best against the hydrocarbons in the soil.
We dont want to use cast iron, what has other disadvantages.
europipe (Chemical)
24 May 12 7:36
Maybe its my bad use of the English language, but I meant:
Take samples of the pipe at location and analyze them somewhere
24 May 12 12:21
Immerse samples of pipe from the field and pipe known to be epoxy and pipe known to be the suspected inferior resin in the hydrocarbon in question and measure loss of properties of each.
Pat
for site rules
Demon3 (Materials)
24 May 12 12:51
You can tell the difference between epoxy and other resins by FTIR spectroscopy. Should cost a couple hundred dollars and most labs can do that.
On a practical note, if PE doesn't work due to hydrocarbon then why not PVC? It's cheap and has a long track record of use in pipes.
Chris DeArmitt - PhD FRSC CChem
Plastic & Additives Webinars
Instant Downloads & Inexpensive
www.plastictraining.com
bobslo (Mechanical)
24 May 12 15:43
Epoxy resin is thermoset material. By heating it up will not melt. Temperature degradation will start direct from solid state.
So use some fire; if material will soften and start to flow it´s not epoxy.
24 May 12 19:31
bobslo
There are more than one type of thermoset. Also when in a composite it is harder to analysis the resin used. two options are performance based tests or chemical analysis. As these resins tend to be quite chemically resistant, analysis with sophisticated machines is required.
Pat
for site rules
europipe (Chemical)
25 May 12 1:17
mr. Demon, PVC is really out of the question, it`s not resistent to hydrocarbons, and degrades faster then HDPE.
Saw it on a site here in the neighbourhood.
Also the mechanical properties are a problem.
Close Box
Join Eng-Tips® Today!
Join Us             Close
