how bend a sipmle tube
i want to bend a "3D cylinder surface element, by applying bending force or rotation Boundary conditions,
i constrained one base of the cylinder ( encastre bc)
I tried using coupling kinematic constraint on the surface of tube , applying UR= value on th reference node,
i didn't got the wanted results, ???
Any suggestion will be appropriated,
