Professional Liability and Business License required for few side jobs per year?
I'm leaving my job soon to begin a PhD and will have the opportunity to do some small geotech design jobs on the side for a contractor I used to work for-- mostly ground anchor design and observing load tests on anchors. The total revenue from the work will almost certainly be less than $15k per year, maybe even less than $5k. Any thoughts on professional liability insurance? The contractor doesn't have any engineers in-house so they don't have E&O insurance, but I could probably use their general liability policy to cover myself. I don't like the idea of not having PI insurance with my stamp floating out there, but looking around it sounds like the minimum possible fee is several thousand dollars per year, which I could never afford to shell out in one chunk. Anybody out there in a similar position?
Also, do I need to get a business license to do this sort of thing? LLC or similar?
RE: Professional Liability and Business License required for few side jobs per year?
"Sharing knowledge is the way to immortality"
His Holiness the Dalai Lama.
http://waterhammer.hopout.com.au/
If you were anything but geotech I might say to just do it as a sole proprietor and don't carry E&O at all, to make yourself less of a lawsuit target, but geotechs are the sort of folks that get sued more than average in my experience. I would say LLC, E&O policy, skip the general liability policy. Go for minimum coverage (250k?) on the E&O and you'll probably be paying around 3k/yr, and another 1kish for licensing and other crap.
I would not do it if you only expected to make 5k/yr. 15k might be worth it. You could probably squeeze 25k to 30k worth of fees into your PhD schedule, if you can get the work.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
First off, if you are not comfortable enough with your skill set to do the work, then you should not be doing the work.
In addition, you may pick and choose the work that you desire to do. You don't have accept all proposed work. You are now a subcontractor and should be looking out for yourself.
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
P.E.s can and will be sued separately from any corporation.
Good point. In addition, I would add that you can also lose your license for unethical deeds.
Isn't this post somewhere else on the forum?
f-d
¡papá gordo ain’t no madre flaca!
