Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...On your site I feel quite confident that the contacts and feedback will make my life a little less hectic..."
Geography
allblowdup (Materials)
22 May 12 15:52
allblowdup (Materials) 22 May 12 15:47
I have a muffler that I have built for a a sport boat. Problem is, it works to well. The boat is way to quiet. Some how I think i have actually got the dimensions correct to cancel out most of the desirable exhaust note. I have look around and cannot find anywher to get any answer on what I should change. I though that maybe someone here might know. It is a v8 engine and the exhaust goes into a 6" dia tube that is 3 ft long that is mounted accross the transom of the boat. It has two inlets that are 4" in dia and are 28" apart c to c. The oultlets are 4" dia alos and are centerd on the tube and are 12" apart.They are all fluch mounted. Have I fluked out and got the distancese so that the exhaust waves are colliding and cancelling each other out? I can shorten the inlet ends of the tube 2" and the outlets 4" if needed. Or I can add length also.Mark
MiketheEngineer (Structural)
22 May 12 16:06
Double posting is frowned upon!!
22 May 12 16:30
Ya whoops I thought I put it in the wrong section. Should I try and remove it from the other one?
23 May 12 13:29
Just pick one or other - Probably this one since there are no responses
Close Box
Join Eng-Tips® Today!
Join Us             Close
