Check-Mate (sketch fully contrained?)
when I run this test, NX find some sketches that aren't fully constrained.
The problem is that I can't find them easy because are internal sketch or because are hidden.
Check-mate give me the name, but how can find where are ?
Thank you...
Using NX 8 and TC8.3
RE: Check-Mate (sketch fully contrained?)
Those who find it trying to move more to parametric. I think find it lagging behind and more volatile. I do like no history. I've always used macros and grips to accomplish the laborious selections filtering required, so with the extra picks added to 7.5, it does suck, sorry. It is going the wrong way to expedite CAD.Regards,
about you last post, I can't see what you are describing.
Thank you...
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Starting with NX 8.5, irrespective of which test is run, the reports will now be consistent when indicating which feature (using the feature timestamp number scheme) a sketch is related to. We have also decided to back-port this fix for the next MR, NX 8.0.3.x, which will be released later this summer.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you...
