water line damaged
water line damaged
i just finished placing unground communication line on state ROW dot contact came out reviewed my permit signed off on it , while i was beginning to trench, and left. ten days later he called and notified me i cut a water line belonging to state . and that i needed to repair, now normaly i will assist on digging up and repair regardless who at fault, but by this time i had allready moved all equipment about 200 miles away, well he said he knew the line was there when he came and reviewed permit, but he never mentioned to me. i want to know , if i am liabl for that water line , , i know it is my responsability to notify every one , in this case they did know ,
RE: water line damaged
did you make a call to the local one-call system? you don't have to notify everyone, just make one phone call. it is required by law in many locations.
http://www.callbeforeyoudig.org/
http://www.azbluestake.com/
http://www.digalert.org/
a) fight this using your attorney vs the state attorney general
b) go back and fix the waterline
