Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site is one of the cleanest and BEST forums that I have seen. I have sent quite a few people your way. Keep up the good work!!!"
Geography
rwild (Aerospace)
22 May 12 10:12
Hello all,
We are looking for recomendations on tooling for machining 6061, 7075, 2024 in the O condition. We have up to 24000 rpm available on a variety of CNC machines. We are currently using OSG Blizzards, and Onsrud single flute up cuts. Both work fine until we get into the O materials. Any input would be appreciated.
MikeHalloran (Mechanical)
22 May 12 18:58
The O condition is great for spinning or flow forming. Not so much for cutting. Can you anneal after machining?
Mike Halloran
Pembroke Pines, FL, USA
Helpful Member!  Zinov (Aeronautics)
23 May 12 22:49
Hi Rwild,
The worst of your aerospace 'gang' will be the 2024. It will be sticking on the tool. O condition worsens the stocking pb.
As you knew it, Climb milling is preferred for these alloys.
Chip load will start large and finish small (there will enough volume to dissipate heat).
for the three alloys avoid using Ti coated tools, PCD tools are the best,why....
Ti thermal conductivity is very low
Al thermal conductivty is very high
--means all heat will stay in the chip that will overheat and stick.
best tooling choice wiil PCD or Diamond if possible
both have very high thermal conductivity and will help to move the heat to the tool and decrease the overheat.
please dont speak in rpm, it does not mean anything,it depends on your tool diameter, You should work with sfm or m/min
Best regards,
Close Box
Join Eng-Tips® Today!
Join Us             Close
