Electronic height gages
Has anyone had any experience with Sarrett Altissimo, Mitutoyo QM, and the Trimos V+ electronic height gages? What are the pro's/ con's, user friendly? etc.
Any input would be appreciated.
RE: Electronic height gages
If in a factory environment, keep it clean and replace the battery often. Otherwise it works great.
I suggest one taller than what you need, it may be worth it some day.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
Nevertheless, from my experience on the shop floor, if it is "digital vs. analogue" question, I wouldn’t want it any other way, but digital.
If you only interested in picking thr right brand, I was using Starret.
Still, I could be measuring different things different way from how you intend to use the gauge.
So, you will be better off asking Manufacturing / Quality Control people.
Good Luck!
Dave D.
www.qmsi.ca
