CurveByTable.Add Method Arguments
Does anyone have experience using CurveByTable in conjunction with VB? If so, could you please briefly explain the proper use of the "Add" method for this object?
I have experimented with various choices for the arguments "Closure", "ClosureType", "UnitType", and "dTolerance" without finding a successful combination. Every time I've run the "Add" method I've received an "Invalid Procedure Call or Argument" error.
A sample line of code would be great, too.
-Jon
-Jon
RE: CurveByTable.Add Method Arguments
Josh
Option Explicit
Dim objApp As SolidEdgeFramework.Application
Dim objDoc As SolidEdgePart.PartDocument
Dim objCurveByTable As SolidEdgePart.CurveByTable
Dim objRefPln As RefPlane
Private Sub Form_Load()
Set objApp = GetObject(, "SolidEdge.Application")
Set objDoc = objApp.ActiveDocument
'CurveType = only igDirectFit and igLeastSquareFit will work
'Closure = igNormal, igClosed
'ClosureType = igNatural, igPeriodic
'UnitType = Null, Character string
Set objCurveByTable =
objDoc.Constructions.CurvesByTables.Add(filepath:="c:\Vb
Examples\CurveByTable\CurveByTable.xls", _
CurveType:=igLeastSquareFit, _
dtolerance:=0.0001, _
ClosureType:=igPeriodic)
objCurveByTable.Visible = True
End
End Sub
Thanks again,
Jon
Mlody
