strange update when clicking on weld symbol
Hello All
Some of out users have noticed that when they are in drafting, and the click on the weld symbol tool, that the status line flashes with updating objects for several seconds. The bigger the assembly, the longer it takes. I have checked all the usual suspects, but I'm a bit baffled. I have attached a link to a video to demonstrate. Any idea what is causeing this.
http://screencast.com/t/0L1XUmseORaa
Many thanks
Si
Many thanks
Si
Best regards
Simon NX7.5.4.4 MP5 - TC 8 www.jcb.com
RE: strange update when clicking on weld symbol
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Sory for the late reply, I've been with a couple of your colleagues (Derek England and co) over at the EMF.
The parts were "save as" from an older version of NX and this was the firt time they had been edited.
Best regards
Now if this only occurs once and if you save the drawing and if you open it again and selecting the weld symbol and nothing happens, then I would say that the system if working as expected. However, if it continues to happen with the same weld symbol every time you select it for editing even if you've saved the file and reopened it, then I would contact GTAC and have them look at it. Now, before you, ask I'm not aware of anything which would force an update to all weld symbols at once. I suspect that this won't even happen during 'refile' since I know that updating anything on a drawing which might have any chance of moving or changing the appearance ever-so-slightly of any drafting object is something we are very careful of since we have many customers who check drawings after an update and even if NO content has changed, but a note or dimension as moved even a fraction of a millimeter we hear about it so drawing updates are handled with very special care.
Anyway, if this only happens once per symbol or drawing, I suspect that this is how it's supposed to work.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
