Stent Modeling
Stent Modeling
I have modeled what I consider to be a fairly complex stent. There are different length column sections, as well as an entire section that has a different pattern from the rest of the stent, so I was not able to simply copy/paste/mirror etc.
I have (2) issues.
1) I have not been able to wrap the drawing onto the tube without leaving a gap at the meeting faces...same issue when I use the flex tool and bend at 360 degrees. How do I go about filling in that gap?
2) The flat model/360 degree bent model I have created is at the tube size that will be laser cut. (.076" diameter) I need to expand this model to .295" diameter. Perhaps I have not drawn the model correctly; which will never get me what I want...but does anyone have any suggestions on how to go about this?
I have (2) issues.
RE: Stent Modeling
Also, the Search function found seven previous "stent" threads. See if any of those help.
RE: Stent Modeling
RE: Stent Modeling
Will the expanded sketch/model have the same number of 'holes' as the original?
If yes, you should be able to use the ModelRescaler macro from http://www.lennyworks.com/solidworks/default.asp?ID=20
RE: Stent Modeling
After staring at the sketch for the umpteenth hour...it dawned on me that I had horizontal/colinear constraints on some of the stuts. After removing those contraints, the sketch changed as I was hoping for.
