Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Many thanks to you for putting it together and to the forum members for taking the time to post their replies and give their time to help others. Their isn't another site that can touch it..."
Geography
ASTM standard test method for ceramic flexural strength
limct (Mechanical)
21 May 12 6:51
hi all,
I am looking for the testing method for flexural strength of ceramic and I come across several different type. Does anyone know the difference between ASTM-F417, ASTM-F394 and ASTM-C1161?
Another question is, whether the speed of the loading will influence the flexural strength of the ceramic? Let's say we have 0.2mm/min and 0.5mm/min, how big would the difference between the two set of flexural strength be?
thanks.
Best regards,
ct
TVP (Materials)
22 May 12 12:33
F394 and F417 has been withdrawn and not replaced. You should use C1161 for your application. I don't have direct knowledge of the difference between 0.2 and 0.5 mm/s. This should be something that a provider of ceramic material could easily answer.
Close Box
Join Eng-Tips® Today!
Join Us             Close
