Material Code Equivalent
We are intended to procure a gyratory crusher component with a reference drawing done in Germany. The material specification is given as stg.52.81 Can someone advise what the BS or EN equivalent is?
RE: Material Code Equivalent
Does not sound like a German Material Nr. Can you post that part of the print?
For instance, if it is st52.3 then the EN equivalent is S355JR or S335J0
