MICRO PILE DRILLED OR AUGUERED?
8" Micro-pile, Steel Cased for 1/2 depth, uncased for the bottom 1/2, grout filled with all-thread rebar.
Is it augered or drilled?
NYC Building Code (2008) (Section 1810.3) calls for different allowable concrete stresses when drilled (33% of fc, vs 25% of fc for auguered)
Why and which applies?
RE: MICRO PILE DRILLED OR AUGUERED?
www.PeirceEngineering.com
As always, talk to the bureaucrats and determine haw they want you to proceed.
