Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...keep up the good work with this forum, I think this is the best one around. ...you actually try to help people learn for themselves. ...I commend you on providing a very good, open learning atmosphere, where usually egos are left behind..."
Geography
Paul6 (Electrical)
19 May 12 18:39
I’ve searched the internet for a long time for hard data on ground effects diffuser design. Finally I found what I thought was a gold mine: Ground Effects Aerodynamics of Race Cars.
SITE:http://eprints.soton.ac.uk/42969/1/GetPDFServlet.pdf
Actually it’s a review of many ground effects experiments in university wind tunnels, many with moving ground planes. Good stuff.
So I went to page 41, and there it was, the GOLD!: two charts showing lift and drag curves (in the Y axis) as a function of h/d (in the X axis). The variable h is defined (p40, fig. 12) as the vertical dimension of the diffuser entrance, AKA ride height. What about the variable “d” ? No definition or explanation is given, as far as I can tell. Do any of the pros on this site have a clue what “d” is? Thanks, Paul6
MiketheEngineer (Structural)
22 May 12 16:04
"d" is probably a dimension - say the width of the diffuser would be my guess???
Paul6 (Electrical)
27 May 12 3:35
Mike, I think you're right. It is very likely to be a dimension. From the diagram on page 40, the only important missing dimension is the height of the diffuser exit. If this were to be the mysterious "d", h/d would be the inverse of the expansion ration, a very important factor. But why the inverse?
Paul6
Paul6 (Electrical)
27 May 12 3:57
Correction, I meant expansion ratio.
29 May 12 11:52
NO idea - it was just a guess
GregLocock (Automotive)
29 May 12 21:41
h/d could effectively be a typo for h/Ld Ld=length of duct, or from the next section h/theta d
Cheers
Greg Locock
Close Box
Join Eng-Tips® Today!
Join Us             Close
