maybe problem V7 to V8
Hi, i'm a new microstation user and i need your help!
i add cells in my DGN file (upgraded from V7 to V8), but when i reload the file they are not there anymore... clicking "save" isn't it enough?
Where does Microstation V8 save my changes?
Thanks.
chiara
Thanks.
chiara
RE: maybe problem V7 to V8
Step one - place some cells and redraw the screen. If the cells are still there, proceed to step 2.
Step two - compress the drawing (does V8 have that?) and redraw the screen. If the cells are still there, you're beyond any help from me and I suggest contacting Bentley.
If the cells disappear after compressing the file, then they are somehow ending up byond the EOF indicator. The simplest fix is to place all the cells in the cell library into an empty drawing - drop complex on all of them, and recreate the cells into a new cell library directly in V8. If anyone has an easier and less time-consuming fix, please speak up.
Rob
Thanks Rob for your help.
Chiara
basila@msdinc.com
