SS shaft with submillimeter bore
Hello all,
I am in need of a 4 mm stainless steel shaft with a center hole of 0.5 mm. I need to fabricate about 100 parts of 4 mm diameter, 30 mm long with o-ring grooves, taper geometries and a center hole of 0.5 mm. While most of the features are doable in a CNC lathe , I think the hole cannot be drilled. Does anyone know where I could find stock material with the hole already there?
