Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Where have you been all my life! I found the answer I needed in seconds..."
Geography
zlindauer (Structural)
18 May 12 19:52
I am trying to use a program called SRWall to design a mechanically stabilized earth retaining wall with gabion facing. The soil will be reinforced with 12 Gage PVC coated welded wire in a 3"x3" grid. There are several input values in the program that I am struggling to nail down. I am wondering if anyone can point me to a good resource for some of these values:
Geosynthetic:
Ultimate Tensile Strength of the Wire
RFcr: Reduction Factor for Creep of the geosynthetic product.
RFd: Reduction Factor for Durability of the geosynthetic product.
Ci: Coefficient of Pullout Interaction of the geosynthetic product.
Cds: Coefficient of Direct Sliding of the geosynthetic product.
Unit to Unit Interface Properties:
Minimum Shear Capacity: Minimum shear strength. This is also 'Y' intercept on the Unit-Unit shear plot.
Shear Friction Angle: The equivalent angle that defines the slope of the Unit-Unit shear plot
Maximum Shear Capacity: Maximum shear strength.
Geosynthetic-Unit Interface Properties:
Min Connection Capacity
Normal Load [IP-1]
Connection Capacity [IP-1]
Normal Load [IP-2]
Max Conn. Capacity [IP-2]
Min Shear Capacity
Friction Angle
Max Shear Capacity
The soil will be processed on site soils, and the soils at this site are highly variable, so I would like to use the lower range of values to be conservative.
Does anyone have experience with this program or have a suggestion for a resource I could use to determine the correct values for the design? Thanks.
Close Box
Join Eng-Tips® Today!
Join Us             Close
