symbol size when embedded in a note
Hi all. I hope you don't mind me asking yet another question here. I am very grateful for all the help I've received in the past.
Where is the default size of custom symbols set? In the image below, how do I change the default values for "Length" and "Height"?
NX 6.0.5.3
Thanks in advance.
NX 6.0.5.3
Thanks in advance.
RE: symbol size when embedded in a note
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
To the best of my knowledge, this file has never been changed, but it seems each time I upgrade NX, the sizes of these symbols change as well. (Has happened the last two upgrades at least. 5.02 -> 6.03 -> 6.05)
I wouldn't mind manually tweaking the size each time if it would 'stick'. But as it is, I have to change the size each time I place a symbol. Also, if I want to put a find number and a flag note in the same note, I cant do it because it makes them both the same size (we normally want find numbers to be .5x.5 and flag notes to be .625x.25).
Several version ago this all worked seamlessly.
