Calculation of position tolerance with reference to hole
Hi all,
When calculating the positional tolerance of a pattern of holes that are on a bolt circle and are located by a shaft going into a hole, do I get any bonus/minus because of the value of the adjustment between the hole and the shaft at MMC?
(See attached)
With the fixed Fastener equation, I would get a positional tolerance of dia0.1 at MMC for the clearance holes (In reference to my DIA50g6)
Because I have a clearance of .009 at MMC between the hole and shaft, do I need to remove it from the positional tolerance?
(See attached)
RE: Calculation of position tolerance with reference to hole
|POS|Ø0.1(M)|A|B(M)
Where A=Primary datum
B=Shaft hole
0.1=Tolerance zone diameter
Total Allowable position tolerance = Position tolerance + Bouns + Datum shift
The clearance 0.009 you mentioned is a datum shift, you need to add it the allowable position tolerance.
SeasonLee
I say no.
Compared to the clearance holes for your holes, your locating feature has a clearance of approximately zero.
The second, and more serious problem is that you have more than two holes. Ignore your locating boss. Your first screw hole locates the part in X and Y. Your second hole stops rotation. Everything else has to pass through the resulting locations. A two hole pattern can be sloppy because there is only one direction of error. The third hole makes accuracy more critical.
Sometimes on easy textbook-style examples where there is only one feature being toleranced in-line with one datum, we may speak of the shift tolerance as being additive. But the actual tolerance zone isn't getting bigger. It's the "effective" tolerance that looks bigger. At any rate, even that idea totally falls apart when discussing a pattern.
John-Paul Belanger
Geometric Learning Systems
http://www.gdtseminars.com
http://www.eng-tips.com/viewthread.cfm?qid=199921
SeasonLee
J-P, I attached another quick sketch with the actual dimensions I would like to put on the drawing.
So from your post, the datum shift is not "usable" to give me a bonus on the tolerance zone of each hole.
Season Lee, I'll take a look at your link.
Jefrojo
But to the main point: this shift tolerance does not mean that the position tolerance available to each hole grows. (That statement is true for bonus tolerance, which comes from the size variation of each of the 8 holes.) The shift tolerance means that the entire pattern of 8 holes may "shift" as a group a little bit off center from the actual axis of B. But notice how that's different that saying that each hole may get its own extra shift.
Also, FYI, I'm not sure why there is a basic dimension of 45º. If the hole pattern needs to be "clocked" relative to the two rounded slots, then another datum is needed. Datums A and B don't help when it comes to clocking. Just an idle thought.
John-Paul Belanger
A minor error noted, the datum feature B size tolerance is -0.009 and -0.025, they are all negative, so the maximum permissible shift tolerance is 0.016. Anyway, you made an excellent interpretation.
Jefrojo
I will give different tolerance on the position callout, normally the counterbore tolerance is larger than the through hole, so you may consider different tolerance callout for holes and counterbores.
SeasonLee
John-Paul Belanger
There is one very important thing you have to keep in mind. Your 0.1 tolerance on 8 holes will work (will assure proper mate with the other part) only if positional tolerance defining spacing between counterpart threaded holes is not greater than 0.1. Or in other words, the sum of both positional tolerances is not greater than 0.2.
This means that 0.08 for this part and 0.12 for threaded holes will work too (or 0.06 and 0.14), but not 0.1 and 0.12.
Yes, for the tolerance on the corresponding threaded hole, I based it on the Fixed Fastener equation, so it will be .1 .
Despite what some GD&T textbooks say, the shift should never be added to the total allowable tolerance. Never. Even in the special case of a single considered feature that is coaxial to a single datum feature, the shift does not allow the tolerance zone to grow.
The figures always seem to show features whose axes are exactly parallel, with no orientation error. This oversimplification creates the illusion that the shift is equivalent to enlarging the tolerance zone. If a feature with orientation error is shown instead, it is obvious that shifting the zone is not equivalent to enlarging the zone. Adding the shift to the total allowable tolerance would accept a feature with a larger amount of orientation error, which would not fit.
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
I think we can add datum shift as a total allowable tolerance if they are coaxial part, here is a good example from Alex's workbook.
SeasonLee
I wasn't able to get the file from your link, but I believe I know the example that you're referring to because it's in several of Alex's books. Unfortunately, this misleading special case is the only example that the book shows. I believe that this has led many people to the incorrect conclusion that datum shift is, or at least can be, additive. The book literally says "the actual amount of datum shift for a part can be additive to the stated tolerance in the feature control frame". I maintain that this is fundamentally incorrect. Even in the single-coaxial-feature special case, the tolerance zone only shifts around - it does not get larger. I'll have to work up a diagram to show this.
In a side note the book says "datum shift is not available on features of size that are gaged simultaneously. For example, there is no datum shift between the holes of a pattern of holes". But no example or further explanation of this is given. I talked to Alex about the datum shift issue at a Y14.5 meeting years ago, and it seems that we've agreed to disagree.
Evan Janeshewski
www.axymetrix.ca
So if you factor in the stated tolerance, the bonus tolerance, and the shift tolerance, in that special case the total offset between the actual diameters will be exactly one half of that total. Thus, the tolerance has been increased.
That said, it is somewhat dangerous to get to comfortable with this idea, since it only applies in that special case! So I agree with most of your post, other than that part where it's "fundamentally incorrect." For this special case it's OK: A tolerance zone that shifts around is essentially carving out a larger tolerance zone. Or maybe I should say a larger effective tolerance zone. Heck, maybe we're just splitting hairs at this point...
John-Paul Belanger
Sorry for I didn't check the link, I am trying to re-upload it again. The 2nd link is Google document in case the 1st link still failed.
I know what you want to say, and I know the difference between bonus and datum shift, the 3rd link is a snapshot from James Meadows textbook.
ETI Workbook page 221
Difference between bonus and datum shift
SeasonLee
I have a strong opinion on this one, and I'm sticking to my guns. I maintain that it's not OK to say that the effective tolerance zone gets larger, even for the special case.
I don't agree that the word "tolerance" is how close to perfect we must be. In dimensioning and tolerancing, the "tolerance" represents the difference between the allowable extremes. So for a spec of 10 +/- 1, the allowable deviation from perfection is 1 but the tolerance is 2.
I agree that in the special case the total allowable offset between the axes of the actual diameters could be no larger than half the total of stated tolerance + bonus + shift. But the next step of concluding that the tolerance has been increased is not correct, because a Position tolerance is not defined in terms of allowable offset between the considered feature's axis and the datum feature's axis. It is defined as the size of a zone, centered at true position, that the considered feature's axis must lie within. This zone allows orientation error as well as axis offset, which is what the textbook example overlooks. So shifting the zone around does not make the tolerance zone increase in size, even in the special case example. If we treat the zone as if it did increase in size due to the shift, then we would pass a feature whose axis was excessively tilted and would not fit.
A tolerance zone that shifts around is carving out a larger something (you called it an effective tolerance zone), but we must be careful to not confuse that effective tolerance zone with the tolerance zone itself. We should call it something else, to avoid this confusion - perhaps the term "spatial domain" might do. The considered feature component (in this case the axis) can span the entire tolerance zone, but it cannot span the entire spatial domain.
The geometry is different, but the underlying issue is the same as one that we disagreed over in Frank's thread about the sphere positioned to a single datum plane. I maintained that the tolerance zone is not the volume between two parallel planes, it's a spherical zone that can freely translate. Using my new term, the volume between the parallel planes would be the "spatial domain" of the sphere's center point.
Evan Janeshewski
www.axymetrix.ca
But using the more generic term "tolerance" (para. 1.3.60) we can say that the datum shift contributes to the total amount by which the actual axes can be off, as you concurred, because this is a comparison back to the axis of the datum feature, not the theoretical datum.
So I'll agree on the general premise: when teaching "position tolerance" we shouldn't lump datum shift into that term. I'm just saying that if we use the definition of tolerance from 1.3.60, in a courtroom setting we could wiggle out of your strict insistence on paragraph 7.2's term (only for this special case of the simple coaxial example) and say that the maximum effective tolerance has increased -- otherwise the two actual axes wouldn't be further apart!
John-Paul Belanger
A special case of a single diameter related to a single datum axis is depicted in fig 5.48 page 144(Y14.5 -1994 standard) and since position could be defined also as coaxiality of features, then the maximum allowable distance between axis of datum feature and axis of considered features is given in the table below the picture.
Therefore, at MMC for that particular example 0.5 = [0.4 pos tol at MMC + (14 MMC-13.9 LMC)+ (25 MMC-24.5 LMC)]/2 right?
Only in these simple cases, doesn't matter if you add the datum shift to the bonus and the positional toleance, you get the same results for the maximum allowable distance between axis, so the same result for the coaxiality and position.
What am I missing here?
Is it a matter of a surface verus axis interpretation?
Thank you
Evan and I were just having fun debating a fine point about the terminology and how we as trainers present the subject.
The 0.5 that you correctly derived will be the maximum permissible offset between the two actual axes. You're safe in just calling that "offset" or "deviation"; calling that 0.5 (or the 1.0 diametrical equivalent of 1.0) the "total tolerance" is what raised that side discussion.
But it must again be emphasized that if you go to other examples where the datum shift is not like this simple case of a single feature, acting in the same direction, then the concept of showing the numbers as in Fig. 5-48 is not even possible (e.g., Figs. 4-6 or 5-2 from that same edition of Y14.5).
John-Paul Belanger
1. Imagine what would happen if datum feature A was referenced at RFS/RMB and not at MMC/MMB: If both axes were perfectly parallel to each other, the maximum allowable axes offset would be 0.45, equal to half of total positional tolerance available (0.9), right? But this would also mean that in the other extreme case, when axis of bigger cylinder is extremely tilted, the linear vertical distance between its beginning and its end could be no more than 0.9.
2. Now, if datum shift was indeed to be interpreted as additional positional tolerance, for datum feature A referenced at MMC/MMB the maximum total positional tolerance of axis of bigger cylinder would be 1.0. And that is not correct since the tilt of the axis can still be 0.9 maximum. Datum shift does not allow it to be bigger.
"Datum shift will never allow it to be bigger".
Notice that I'm just summarizing the possible effective tolerance; it's not a blanket statement about what the position tolerance is always and everywhere!
As an analogy: Consider how Rule #1 controls flatness across the top of a rectangular block. And suppose the height tolerance is ±0.5. You guys wouldn't have a problem with me saying that the maximum possible flatness tolerance could be 1.0. Now if that top surface were tilted to the extreme permitted by the size, then we would say the flatness tolerance is now 0.
Simply paste that analogy onto this coaxial example! If you start tilting things, certainly that eats into the other variation that might be possible.
I think it comes down to this: you saying that "the position tolerance would be..." (which I agree is not a correct blanket statement)
versus my use of "the position tolerance could be..." (which can be fine if understood along the same lines as the Rule #1 example given).
John-Paul Belanger
I am having a problem with grasping the analogy. In your flatness example there is no "external" factor (like datum shift in case of coaxiality) that could (or could not) influence the value of acceptable flatness error. It is obvious that flatness actual error can be 1.0 max and nothing can change that.
Additionally for flatness example the tolerance zone can tilt itself since it is not tied to any datum, while for coaxiality the tolerance zone is fixed in rotation to datum axis A... I am really having difficulties to see your point...
But what I meant is that when an external factor drives a tolerance, any other variation thrown into it may reduce what's really available. But it's still permitted to say that there is such a thing as a "maximum possible" value.
John-Paul Belanger
I can find out at least two more examples from Alex's training material that datum shift can be added as a total allowable tolerance, and they are not cylindrical coaxial part---the special case as we mentioned earlier.
SeasonLee
I'll try another one of my goofy analogies: Suppose my car is at rest in the garage, and you ask me how much space it takes up. I'll give a certain answer (such as "x" sq. ft.).
No suppose I'm driving my car in tight circles and you ask me how much space it takes up. My answer will be different, and it will be a larger number.
So with shift tolerance, we realize that the position tolerance itself doesn't grow (my car didn't grow), but having the position tolerance move around effectively contributes to the tolerance, if that word is properly understood.
John-Paul Belanger
