Please help with fixture advisor (elastic support)
Hi guys,
I am doing FEM analysis of a rigid chain scissor lift.
My question is how to present the chains? May be as an elastic support with a certain stiffness?
RE: Please help with fixture advisor (elastic support)
Actually the thing is I am not sure about the normal (axial) and shear (transverse) stiffness values that I have to put when defining elastic support.
Any ideas on how to find them the right way?
I calculated using this formula: k=AE/L and I get 343 200 000 (N/m)/m^2
I'm not sure if it is correct but I assume it to be.
For transverse stiffness I still haven't put any value.
Here are two more pictures. Mine scissor lift looks like the one on the picture.
And the second picture is the rigid chain actuator itself.
Basically, what troubles me is how to define the restrains in the correct way.
Anyways, thanks again.
Cheers
A kinematics solver would make easy work of it.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
