Bearing Terms
Bearing Terms
Bearing Terms
Hello All
I found this code in one electric motor bearing and I would like to know what means.
6312 2Z/C3 GWP/R806, 6312 2Z is clear, but the other letters GWP/R806 no.
Thanks for the inputs.
Carlos
RE: Bearing Terms
I don't know for sure but I would bet that GWP/R806 is calling out a special kind of grease.
RE: Bearing Terms
Tough question. You might try bearing forum.
Where are you reading the part number from?
What manufacturer is the bearing (should be stamped on the bearing)?
Is there an AFBMA number (including suffixes) listed on the motor nameplate? (should start with 60BC03... what comes after that?)
What type of motor?
** If this is simple horizontal motor with no special requirements, I'd think any 6312 2Z/C3 would do. When you replace the bearing, put compatible grease into cavity (half full) as what bearing manufacturer will provide within the new double-shielded beairng. (usually Polyrex EM will be fine... compatible with most)
(2B)+(2B)' ?
RE: Bearing Terms
Call the mfg
RE: Bearing Terms
Call the manufacturer goes without saying.
One thought - is the motor operate in a high temperature?
(2B)+(2B)' ?
RE: Bearing Terms
Thanks for the Inputs
The bearings belongs to one fan induction squirrel cage motor mounted in one subway. The manufacturer is SKF and no AFBMA code, the letters and numbers are wrotte in the external bearing race way. We are in contact with the manufacturer and for the moment no answer.
Carlos
RE: Bearing Terms
GWB is definitely a grease code. Polyrex EM perhaps, but a call to the SKF tech line should resolve that. The /R806 is probably a fill volume or other modifier on the grease.
David
