Alternative for Flushing Pipes
Hi Everyone,
I've been asked to look into the process of "Froth Flushing" by my PM.
I've started a web search and, so far, most of the websites I've been to have the exact same information. Even the wording is almost identical. I'd be interested to hear any comments from any exposure any of you have had to the process. Were you impressed by the process?
Below is a link to a document on Froth Flushing. It is not the same as the hardcopy I have but the information is the same (word for word).
http://www.boyleenergy.com/images/FrothFlushing.pdf
Thanks in advance for any feedback.
RE: Alternative for Flushing Pipes
80 fps. tie your pipe down and make sure all valves stay OPEN.
What would you be doing, if you knew that you could not fail?
Big Inch,
Thanks for the reply. What are your thoughts of the Frothflush vs traditional methods?
Unfortunately I haven't had the opportunity to see it in action.
