Deadheaded fan power requirements
I am looking to test the fan blades on a fan (12,000 CFM at 150HP) for a life cycle of start and stop cycles. Not nessesary to actually move air for this test as the CF loads on the blades are what folks are concerned about. How can I figure out what HP motor to use (hopefully much less than 150HP) if the fan is "deadheaded".
RE: Deadheaded fan power requirements
You may want to run a test or two to check your assumptions.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
good luck!
-pmover
(2B)+(2B)' ?
(2B)+(2B)' ?
I guessed CentriFugal, but we all know what assumptions make us.
