Zinc based Primer on Stainless Steel Flange
Problem:  Overspray from painting a carbon steel unit coated a stainless steel flange with a zinc based primer.  We are worried about possible field welding that might allow the zinc to penetrate the stainless steel resulting in liquid metal cracking.
Question:  What is the best way to clean the stainless steel flange without sand blasting the unit.
