Two questions: 1. Can you have two
Two questions:
1. Can you have two different sets of ordinary group II (130 sq ft max coverage) coverage styles in the same room?
2. Can sprinklers be more than 15 ft apart if the lines of intersection of their coverage is less than or equal to 15 ft apart in the direction of their 15 ft coverage?
The picture will hopefully explain my questions better. The dilemma is that the coverage areas for the sprinklers match up in the picture, but there are two problems.. one is that the styles are different in the same room, and the second is that the sprinkler distances to eachother exceed 15 ft in two cases, yet not if you measure from sprinkler to centerline of another sprinkler.
RE: Two questions: 1. Can you have two
