"Stubby" Hollow Plunge Cylinder
Does anybody know of a "stubby" Hollow Plunge Cylinder. Ideally, I would like somethign akin to a pancake cylinder but with a hole through the middle. To get a rough idea of dimensions, the inner diameter will need to be about 70mm and the length would need to be 150mm max, smaller is better. Travel distance will be <50mm and thrust to be applied is 5kN.
Enerpac seem to be the dominant brand and I can't seem to find another manufacture of this kind of product.
Does anyone have experience with these types of devices?
Steve
Steve
RE: "Stubby" Hollow Plunge Cylinder
The problem I'm having is I need a large inner diameter (70mm ish) and minimum length. I don't even need for the plunger to travel far.
Enerpac do a 79mm inner hollow cylinder but it is 250ish mm in length which is too big for me. I need something smaller.
Cockroach
