SA 312 TP316Ti
SA 312 TP316Ti
SA 312 TP316Ti
Are there any tables for Stress Allowance for SA 312 TP316Ti or SA 182 F316Ti? ASME II Part D does'nt cover this material, where can I find Stress Allowance table acceptable to the ASME Code containing this materials. Please reply.
RE: SA 312 TP316Ti
You won't if there are no stress lines in Section II, Part D. You can review if there are Code Cases for this material.
RE: SA 312 TP316Ti
Last time I used this material, the Client and the Third Party Verifier agreed to accept my calculations for allowable stress based on the plate and forgings test results. Not in accordance with the code, but worked for me. I used in preliminary calcs the values for 'H', then I reworked it for the calculated allowables.
Cheers,gr2vessels
RE: SA 312 TP316Ti
Thank you guys!
