FLOATING MANHOLE COVERS
I am installing floating manhole covers and would like to know the proccedure for laying the asphalt around the rim, the size of the hole is 4ft.x4ft.x6in.
Thank You.
RE: FLOATING MANHOLE COVERS
IT's probably redundant by now.  The frame should have a rim on it about 2" lower from the top of the frame.  This is to compensate for the last lift of asphalt.  Depending on your design, I would follow th manufacturers recommendations.  In general, on roads with a 6" lift, I have placed the frame and cover on top of the first lift of asphalt and then continued with the final lift.
