Assembly went screwy after using hole wizard
Hi all,
I was adding a hole to one of the components in my assembly. After I checked the check mark to accept the hole the assembly disappeared. I tried fit to screen, scrolling with the mouse in and out and nothing. I then closed the file and reopened it and it opened weird. Components are on top of another. Pieces are transparent, other components are missing. I have never seen anything like this before. Anyone know how to fit this? Did I hit a key that did this?
I really hope someone can help me.
Mark
Mark
RE: Assembly went screwy after using hole wizard
What video card & driver?
Are configs or display states involved?
Were you adding the hole while editing a part in the assy, or adding a hole at the assy level?
I'm using sw2011 sp 0.0.
ATI mobility Radeon HD 5870 driver version - 8.850.0.0
At the time I had my lap top hooked up to Asus monitor but right now I have SW running off the lap top alone and same thing.
When this happened I was editing a part in an assembly.
I have been using SW 2011 for almost a year now, used 2010 and 2009 and never have seen anything like this.
Radeons are not approved for SW use so you will not find a recommended driver at their site. You could try installing the latest driver from ATI.
AFAIK, the problem you describe is not typical of the Radeon card, but many strange things can & do happen when gaming cards (Radeons and GeForce) are used for SW.
Mark
Cheers,
Anna Wood
SW2011 SP5, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
