Table Borders
Table Borders
Table Borders
I'm having a problem with adjusting the table border of a row/cell. Whenever I try to change the border (to Top for example), it always reverts back to All when I hit apply. Is there some setting or rule I'm missing?
Chris
NX 7.5
RE: Table Borders
Starting with NX 8.5, when you select a cell in a Tabular Note, the 'Border' section of the Style dialog will reflect the current settings previously assigned to that particular cell, such as if one side was set to be invisible or you changed the width. While the initial setting will always be 'All' when editing a new Tabular Note or one that hasn't have any of its cells edited priviously, once you edit a cell it will reflect the current status of the selected cell the next time you go to edit it, which is better then even Excel which always keeps the LAST selection during the current session and does not reflect the status of the currently selected cell.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
