Matlab and xpc
Matlab and xpc
I build simulink model which works in simulation mode, but it is not possible to build it for xPC-target real-time machine.I think that the SFun_GenericClient funcion(which coded by c++) must be rewritten exploiting the UDP send and receive block provided by xPC target.
How i can resolve this problem with winsock?
for better understanding i give here error message....The call to xpctarget_make_rtw_hook, during the exit hook generated the following error: Invalid Simulink object name: loader The build process will terminate as a result.
