Welding 12" sch 40 pipe with 12" sch 20 WN flange
Hi Everyone..!
Due to mistake of procurement we have 12" 300# Sch20 flanges delivered at site instead of required 12" 300# Sch40 flanges.
Is it permissible to trim the pipe ends for weldability..?
Line conditions are
Oper. Press.: 24.53 Kg/cm2 g
Design Press.: 48 Kg/cm2 g
Oper. Temp.: 45 C
Design Temp.: 87 C
Line conditions are
Oper. Temp.: 45 C
Design Temp.: 87 C
RE: Welding 12" sch 40 pipe with 12" sch 20 WN flange
Considering what happened, I would reject the fitting for use in this pipe system.
My concern is these flanges are to be installed at pump discharge. Should I take the risk of installing Sch20 flanges or not..??
