UGmaster/UGpart check in NXopen vb.net
Is there a way to check if the file is a UGmaster or a UGpart in NXopen vb.net (NX7.5)?
Reason being is that I created a quick program that runs off the part callbacks (Save, SaveAs) that will populate attributes but I only want them created in the UGmaster. (They then get mapped to the Teamcenter item revision and then mapped back to the UGpart if one is created)
Any Help would be appreciated
RE: UGmaster/UGpart check in NXopen vb.net
Check out the .FullPath property of a UGPart vs a UGMaster, there may be a useful difference.
www.nxjournaling.com
