Hot Water Sealing
Hot Water Sealing
I understand for temp >180F we should be using a cooler to seal..what if the pressure is high enough to exceed the vapour pressure of water considersably..is taht OK or should we still be cooling? Somebody told me that the lubricity characteristic of water goes down, hence exceeding the vapour pressure is not suffice and we should cool..is this correct?
RE: Hot Water Sealing
I should also note, that the preferred o-ring for hot water is often Ethylene Propylene (EPR). EPR is rated for continuous service up to 300 °F. But, the o-rings are subjected to some of the heat generated by the seal. If the o-rings are running above 250 °F, they may experience reduced life. This is improved with cooling. If you change to a high temperature bellow seals to get away from the temperature limit, then you have a potential problem with pressure. Most typical bellow seals are only rated to 300 psi. I don't know what process you are working with. But most of our relevant applications are boiler feed water. And, the pressure is often much too high for bellows.
I consider water to be one of the most challenging fluids to seal with a mechanical seal. You need all the advantages you can get. Cooling helps in a number of ways.
Johnny Pellin
