ASME B16.5 CL600 Flange Rating
The three of us got stumped yesterday on this matter and we've been investigating when we can. i was not successful with search in this forum even though i believe it has been asked before.
Essential criteria:
Piping Code, ASME B31.8
ASME B16.5 12-inch, RFWN Std Flange, A105 Material
30° - 200°F Temp Range
Piping MAOP = 1050-psig
Pipe Material, 12-inch, X52, 0.375wt
ASME B16.5 Group 1.1 lists this flange rating at 1480-psi. Although the flange thickness at weld does not meet the P=2StFET/D in B31.8 for an Class 4 location (compressor station). So, we think a higher strength flange material is needed per MSS SP-44.
ASME B16.5, paragraph 2.7 (I think as i do not have reference with me) states something about Bmax. Please clarify where/when this applies.
Can this flange be utilized and comply with applicable codes? I'm requesting clarification/direction with references in B16.5, MSS SP-44, or otherwise.
thanks!
-pmover
Essential criteria:
thanks!
-pmover
RE: ASME B16.5 CL600 Flange Rating
What would you be doing, if you knew that you could not fail?
B31.3-302.2.1 and 303
- Steve Perry
http://www.linkedin.com/in/stevenhperry
This post is designed to provide accurate and authoritative information in regard to the subject matter covered. It is offered with the understanding that the author is not engaged in rendering engineering or other professional service. If you need help, get help, and PAY FOR IT.
-pmover
