The emboss die, how to do that?
Hello
Im working on a metal sheet to emboss and I need to manufacture the die that embosses it
My sheet is:
http://files.engineering.com/getfile.aspx?folder=d9015aa8-f409-46df-a072-e9c3fc32827d&file=Sheet.PNG
My probleme is that I cant find a way to model the die that creates the embosses on the upper face.
Any suggestion?
Thank you
My sheet is:
Any suggestion?
Thank you
RE: The emboss die, how to do that?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
I guess that a simple method would be to extrude the die cross section thru the sheet, then use Insert - Trim- Trim body.
Depending on the size of the extrusion you would get both options.
Regards, Tomas
Thanks, that works perfectly, the emboss is done on one single punch.
The trim body gives exactly what I want.
Have a good day
