HOLE SERIES ISSUE
HOLE SERIES ISSUE
I am trying to start a Hole Series in an assembly and unable to select existing holes that were created using Hole Wizard using a 3d sketch (holes are on different different planes on one part). Hole series is not recognizing these holes.
Is Hole Series not able to use existing holes that were created in 3d sketched Hole Wizard holes?
Mike J
Mike J
RE: HOLE SERIES ISSUE
SW Premium 2011
64 bit SP4.0
Intel Xenon X5650 @2.67GHz
2.66 GHz 11.9 GB of RAM
