Is this note make sense to you?
PartNotex | UNLESS OTHERWISE NOTED WITHIN THE CATIA DATASET, ALL PARTS ARE LOCATED TO A SURFACE PROFILE TOLERANCE OF .0600 RELATIVE TO PRIMARY DATUM A, SECONDARY DATUM B , AND TERTIARY DATUM C. EXCEPTION FOR DA LOCATED DETAIL PARTS, THE DETAIL PARTS TAKES PRECEDENCE FOR PROFILE TOLERANCE. | URL
RE: Is this note make sense to you?
| Profile | .0600 | A | B | C |
ALL OVER
Using the symbol instead of the text would be recommended, in my opinion. Also, this spec assumes A, B and C datums are always specific.
Matt Lorono, CSWP
Product Definition Specialist, DS SolidWorks Corp
Personal sites:
Lorono's SolidWorks Resources & SolidWorks Legion
Exception given to “parts” probably mean that your nuts and bolts are allowed to have their own datums, not related to “major’ A, B, and C.
There should be document somewhere (paper or electronic) showing where the datums actually are.
Just a thought. If it deviates from conventional standard, it should be explained somewhere.
This type of statement is made in the standard as an option.
Frank
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
Frank
Like a feature control frame in Braille? :)
John-Paul Belanger
Geometric Learning Systems
http://www.gdtseminars.com
Frank
That said, such "standard" notes need to be used with care to ensure that the meaning is applicable to the part being defined.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
ISO provides “text equivalents” of GD&T symbols, which makes sense. You cannot expect every font in the world to include GD&T symbology, so sooner or later your text document will become corrupt.
The abbreviations are as follows:
Line profile PFL
Straightness STR
Roundness RON
Surface profile PFS
Flatness FLT
Cylindricity CYL
Angularity ANG
Parallelism PAR
Perpendicularity PER
Position POS
Coaxiality CAX
Symmetry SYM
Circular run-out CRO
Total run-out TRO
I see no reason why we couldn’t start using them for consistency’s sake.
Jim Sykes, P.Eng, GDTP-S
Profile Services www.profileservices.ca
TecEase, Inc. www.tec-ease.com
Speaking of which, things that I see everyday make me think that majority of people don’t understand symbology and have to be presented with the text…
Essentially I put a bunch of spaces in the note and then drop a separate surf profile box in the space.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
The real advantage to drawing symbology is that it is language-independent. The more you can express tolerances and design intent with symbols, the less chance of some Spanish or German QA misinterpreting the meaning. If your drawing is guaranteed to go to an English language manufacturing environment, and your organization is fine with wordy notes, then fine. Otherwise, using tolerance frames and symbology is very beneficial to all parties involved, and hopefully leads to far fewer mistakes.
(Sorry, couldn't resist)
Nice post on the font, Thanks
