HV fluctuation problem
I have a Bystar 3015, if I try to run it at more than 70% power a couple of tubes fluctuate and fall on their face. The resonator then begins to blink like a cheap beer sign in a pub window. I was told by a friend/tech to tap up the transformer in the HV cabinet. My question is do I tap up or down? If my HV fluctuates, and it does, is 5% of the 540 tap better than or worse than 5% of the 470 tap? I know the numbers deal and their answers, but is the loss due to fluctuation enough to cause my problems with a couple of tubes? Any help is appreciated.
Thanks... 'b'
Thanks... 'b'
RE: HV fluctuation problem
a high voltage probe helps but is not absolutely necessary.
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
