PARTS LIST NX6 DB_PART_REV WON'T UPDATE
I cloned an assembly where one of the components was at teamcenter rev.B. The rest were at rev.A. All the parts new cloned parts are at rev.A except that one part shows up as rev.B in the parts list. It's the one that was cloned from the rev.B part. I checked back to the part and DB_PART_REV is set to A. I have updated the parts list, deleted it and put it back, and anything else I could think of to no avail.
Jeff Younie
RE: PARTS LIST NX6 DB_PART_REV WON'T UPDATE
this has helped me with several parts list related problems, not sure if it will help in this case:
in drafting go to your assembly navigator
right click on your assembly (not the one with -dwg1 behind, but the one below that) and select properties
in the assembly tab, under the "synchronize subassembly properties" click Attributes.
This may fix your problem.
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
It worked! I knew there had to be a way. Thank you very much.
NX 6.0.5.3 TC 8
Windows 7 64bit
Intel Xeon @3.07GHz - 8GB RAM
Nvidia Quadro 2000
