JOURNAL HELP TO EXPORT VIEWS TO PDF
I have recorded a journal to export a model view to append to a pdf, I used the record feature because I have no programing experiance. We are creating views in modeling with PMI definition, the format that we use to name the views is MBD_01_Discription ( all views start with MBD_ then a 2 digit number starting at 01 and up, then _with a discription of the view). We have a drawing view in tha model that we have a format on, this we export as a pdf, then go to each view and export as an appended pdf. I would like to have a journal export append a pdf of all of the MBD_XX views in order. the quantity of numbered views varies per part, but never more than 100 views.
Thanks!
Thanks!
RE: JOURNAL HELP TO EXPORT VIEWS TO PDF
The first view is of your format (drawing title block)? Other views after that are appended, so they get their own sheet in the pdf file. Only the first view has the format? Do you need a certain sheet size and/or view scale for the views?
www.nxjournaling.com
the tedious part is going to each view and appending it to the pdf. we export each view set at E-size 43x33 to match the first drawing sheet. i've changed my customer defaults so the views retain its size as saved, so I dont have to restore the view every time I open it.
Hope that makes sence.
Thanks !
- drawings should be "E" size
- only views starting with "MBD_" should be exported
I suspect there will be other changes as well.CODE
