UTS & YS for 2014 Al and 7075 Al
I'm looking for UTS and YS data on two types of post HT aluminum wire.
Material #1: Aluminum 2014 wire
Incoming state: H13, 35-40ksi UTS
Heat Treat: Solution at 935 deg F for 50-60 mins, water quench, natural age at room temp for 96 hours
Material #2: Aluminum 7075 wire
Incoming state: H13, 31-36ksi UTS
Heat Treat: Solution at 870 deg F for 50-60 mins, water quench, then 1st step age at 240 deg F for 3h45m-4h5m, air cool, then 2nd step age at 325 def F for 5h45m-6h5m, air cool, then 3rd step age at 350 deg F for 7h45m-8h5m, air cool.
All temperatures are +/- 10 deg F.
Thanks for the help!
RE: UTS & YS for 2014 Al and 7075 Al
2014-T4 has yield ~ 42 ksi, UTS ~ 62 ksi, and El of ~ 20%. Source: ASM Handbook Vol 2
7075-T7351 has YS > 57 ksi, UTS > 68 ksi, El > 7%. Source: DOT/FAA/AR-MMPDS-01
