Preferences for UGII_ENV.dat file
We are updating machines to windows 7 and adding more ram to help with the memory errors. Previously our windows xp machines ran 32 bit NX and all pointed to a custom ugii_env file on the network drive. This file didn't work with the new installs of nx 64 bit. The default ugii_env file was used but things like reuse library and symbols weren't showing up. We've tweaked the file using the default and settings from the 32 bit custom file and have gotten these items back. I noticed when the ugii_env file is placed on the network drive the speed of nx updating views and opening files is slower. We have now moved this file locally on each pc to the local drive and the speed has gotten better. Is there any issues with the placement and which is preferred. For now local seems much better. Placed on the network made easy updates for IT.
RE: Preferences for UGII_ENV.dat file
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Do you see anything wrong in this file? It makes drawing view updates 3 times as long also loading of parts if used on the network.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I don't understand why things are quicker. Should we copy the Configuration folder locally? Would this help our speed out?
John R. Baker, P.E.
Industry Sector
Cypress, CA
John R. Baker, P.E.
Industry Sector
Cypress, CA
