Super Duplex CE8MN - Saveable or not?
Dear all,
I got a Super duplex stainless steel CE8MN and although composition seems in spec the ratio of ferrite to austenite is nowhere near 50-50.
Take a look at the micrograph. Etchant is Murakami which colors the Ferrite. I would say that I see 20-30% Ferrite which as you understand will cause reduced mechanical properties that are out of spec.
The castings have been heat treated with a resulting hardness of 260HV.
Q: Is it possible to alter the % ferrite to austenite ratio by tailoring the heat treatment? Or am I stuck with the schaeffler diagram which is based on the composition.?
Herc
RE: Super Duplex CE8MN - Saveable or not?
If the composition, especially the nitrogen, is correct, you may be able to do a high temperature solution anneal to grow the ferrite, say 1100C.
Michael McGuire
http://stainlesssteelforengineers.blogspot.com/
Hope they are raw castings to be reheat treated. If they have provided a test bar,you may want to test in a small furnace for the results.
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
Resolutionize and cool by the book; i.e. manufacturer's process.
Yes, changing the anneal temp will shift the AF ratio.
A higher anneal temp with very aggressive cooling will result in higher ferrite levels. If you cool fast enough you will have higher than equilibrium amounts.
Plymouth Tube
