Field Cutting and prepping ASTM A335 Gr P91
I need to cut out some components in a socket weld (SW) A335 Gr P91 line.What is the best method for cutting and preping to avoid thermal damage to the material?
RE: Field Cutting and prepping ASTM A335 Gr P91
We would normally grind out the socket weld or use a portable band saw to remove the component.
Local grinding.
At ambient temperature?
Yes.
