Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This is a very good site. Please keep it running. Thanks and wishing a great health and success for the site and its owners..."
Geography
tabtab (Chemical)
15 May 12 3:37
Dear Freinds,
In the refinery flare system, I have seen that the pipe that is connected to the flare stack have the same size of the flare stack. And in some cases the pipe has been enlarged to the size of flare stack before the connection.
My questions are:
1)why the pipe which is connected to the flare stack should be in the same size of flare stack?
2)what are the criteria for calculation of how far from the stack, the pipe should be enlarged?
3)any reference or procedure for calculating will be highly appreciated.
thanks
poli60 (Chemical)
16 May 12 2:07
Calculations relevant to flare system piping are covered by "compressible flow" section in Crane technical paper 410.
Flarenet is an A$pentech s/w specialized for flare system hydraulics. Other few similar s/w are available on the market.
In the final part of the flare header flow, temperature and pressure of the fluid are very similar to the ones in the flare stack. Each single pipe in the system shall respect a max velocity criteria: since the velocities are very similar, the two sizes are usually the same. This is only a quick answer: things are a little bit more complicated....
Available for other discussions on this subject.
Close Box
Join Eng-Tips® Today!
Join Us             Close
